Welcome to Club SAITO !
Old 04-07-2007, 09:12 PM
  #6976
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Default RE: Welcome to Club SAITO !
I was looking at my Saito .30 yesterday that Bill had for a few months, he colored the cylinder black while he had it. It's a prized possession now.
Old 04-08-2007, 01:22 AM
  #6977
rustypep
I have decided that I am going to put my old 40 size trainer on floats but am trying to decide which engine to use. What do you guys think a 65, 72, or 82? I still want to be able to swap back and use it as a trainer if I have someone to help but I am really not sure what difference there really is between the 65 and 72 and what would be enough on a 40 sized water plane. It still has the original 40 FP in it. The plane is an Easy Fly 40 (1998) which was one of the early variants of what is now the H9 trainer. Thanks for the help in advance.
Old 04-08-2007, 03:51 AM
  #6978
Dave :^)
Dave :^)'s Avatar
Sorry guys
Those HAW's bring a tear to the eye......
..... and a smile to the face!
Dave :^)
Old 04-08-2007, 06:41 AM
  #6979
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
A .62 would be perfect for it. They are a smooth, sweet running engine.
Old 04-08-2007, 10:16 AM
  #6980
freeonthree
freeonthree's Avatar
My math skills are not so good, does this make sense ? I took a fresh gallon of R&T 20/20, poured out exactly a quart, then added a quart of methanol. At that point I figure I have 15/15, then I added an ounce of castor, which I think brought my oil content up to just shy of about 16%. Am I thinking correctly here ? Or am I overlooking something ? Dennis
Old 04-08-2007, 12:24 PM
  #6981
rlmcnii
freeonthree,
Math looks good.
Old 04-08-2007, 02:43 PM
  #6982
freeonthree
OK, thanks ! Whew ! Thats a relief... A friend of mine came up with that idea because I like to buy my fuel from a friend who stocks the stuff for their local club as a convienence, but that 20/20 is too oily and smokey. Now it seems much better at least. I have only run a Magnum 70 with it so far, because if that engine fried I could care less. lol
Old 04-08-2007, 02:57 PM
  #6983
rlmcnii
freeonthree,
It works out to 15% nitro and 15.78% oil...depending on the accuracy of your measuring..call it 15.8%. Your Saitos will do well with it.
Old 04-08-2007, 03:34 PM
  #6984
freeonthree
Thanks ! I like the sound of that... Now to tune the other planes to it.
Old 04-09-2007, 11:23 AM
  #6985
Sukhoi Doug
Hi Everyone,
I should have joined the Saito club a long time ago. The smallest Saito I have is a 1.00 and I have 4 of them, I also have a 1.20, 1.50 and 2 - 1.80’s, I also have a 3.00 with twin carbs & plugs.
Doug
Old 04-09-2007, 11:48 AM
  #6986
RC Specialties
Welcome to the forum Sukhoi Doug. You will find many nice folks here.
Jim
Old 04-09-2007, 12:00 PM
  #6987
blw
blw's Avatar
You are #508 Doug.
Old 04-09-2007, 12:05 PM
  #6988
freeonthree
How did we get up to the 500's so quickly ? Wow !
Old 04-09-2007, 04:18 PM
  #6989
freeonthree
OK guy's, here's one for ya. Even Horizon Hobbies never heard of this engine ! G60F gas engine, 9.96cc = .60 + a tad
http://cgi.ebay.com/SAITO-GASOLINE-E...QQcmdZViewItem
I'd like to have it just to display !
Old 04-09-2007, 04:33 PM
  #6990
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
A poster here named Bruce Loughridge has one of those in his engine collection.
Old 04-09-2007, 04:41 PM
  #6991
freeonthree
Cool... I'd like to know more about the G60F, like what size prop will it swing, and weight. I wonder if he has run his at all... I'd love to here about it. I think it must be a Japan only engine. It has elect ign so it can't be that old...
Old 04-09-2007, 05:28 PM
  #6992
jessiej
ORIGINAL: freeonthree
I believe I see a coil & condenser in the pic. Model engines used that type ignition as far back as the 1930s. The glow plug didn't come along untill 1947 or so.
Old 04-09-2007, 05:38 PM
  #6993
freeonthree
OK, but that Saito runs on gas/oil mix like a DA150 ! Smallest gas engine i've ever seen...
Old 04-09-2007, 07:15 PM
  #6994
proptop
My Feedback: (8)
proptop's Avatar
I don't know if they still make that particular engine or not...but I remember seeing the ads for them back in the late 70's.
I believe they were sold before the glow 4 strokes became popular or even available?
Old 04-09-2007, 07:24 PM
  #6995
roboto65
My Feedback: (30)
roboto65's Avatar
What a good day today finally got my Saitos set right they purr like cats heheheh no kittens here thanks to this forum and all the advice from the Bill,Hobbsy and the rest of the guys had a little fun getting them right but once I steppped back and started from scratch with the High and Idle got them going great know to get the rest of the bird ready hehehehe !!!!!
Old 04-09-2007, 08:44 PM
  #6996
jessiej
The old ignition engines usualy run on 3 parts gasoline to one part 70wt motor oil. The smallest that comes to mind is the Arden .09. There were dozens of manufacturers of ignition model engines, most sadly defunct now. Many of the old engines are still im use in Society of Antique Modelers events. (Check out the SAM web page- you will find it interesting).
jess
Old 04-09-2007, 09:41 PM
  #6997
Sukhoi Doug
Hi Everyone,
Thanks for all the welcomes, it’s nice to be here, I do love my Saito’s, I have had such good luck with them it’s unbelievable. My pride and joy is the Saito 3.00TTDP. I got it to go in a Great Planes PW Extra. I do have a couple questions that maybe someone here knows more about than I do. The Saito 3.00 has a built in pump, it’s not really a pump from what I see, and it uses crank case pressure to pressurize the tank, correct? The reason I ask is because I would like to put the tank on the CG, will it work, or am I asking for trouble? The other thing is I would like to run a on board glow driver, I have found a couple of them I like, I would like to run a lipo battery but can’t seem to find a regulator that will drop the voltage to 1.5 volts, it seems like someone should have one, I have looked but not having much luck.
Thank you all for having me,
Doug
[sm=idea.gif]
Old 04-09-2007, 10:34 PM
  #6998
freeonthree
Thank Jesse, what does SAM stand for, so I can check it out.
Old 04-09-2007, 10:44 PM
  #6999
blw
blw's Avatar
Welcome back, Jess. Good to see you posting around here again.
Old 04-09-2007, 11:15 PM
  #7000
Bladejunkie
Hey blw,
I've got three Saito's now an FA56,a FA65,and a FA82 do I qualify for club Saitohood?
Thanks Bladejunkie
