Welcome to Club SAITO !
#6078
It is called the TurboHeader. It is manufactured and distributed by RC Specialties. It weighs 2 oz. which is 1/4 oz less than the stock muffler. From the exhaust port to the outside edge of the header is 7/8". It has a great tone and provides an average increase of 200-300 rpm. Contact [email protected] for more info. It will show up under new products within a couple of days.
Thanks for asking!
Jim
Thanks for asking!
Jim
#6081
Birman,
I don't have a website set up yet. You can contact me at the email listed above and I can give you the details. As for the 90 degree bend, it is machined with plenty of wall thickness and the material is very strong. Can't give out all the secrets. Contact me if you would like more info.
Jim
RC Specialties
Jim
RC Specialties
#6083
It was designed for the FA 100. See ad#255654. You can find all the info there. If you have any questions send me an email at [email protected].
Jim
Jim
#6084
ME
jrc,
Really dresses up the Saito 100 as welll as being very functional! Any chance of getting a soundbyte in here so we can hear it? Got a feeling this is gonna be a hot item, can't wait to get one..........mstcitabria
#6085
MST,
I will work on the audio. I am busy getting it on the market, but I will work on it. I appreciate your comments and it is very functional. I am a fellow modeler and it has worked great for me.
Jim
Jim
#6093
![](/forum/images/badges/trading_plus_member.png)
My Feedback: (15)
LA
How does the performance of the FA 125 differ over the 120? I have been flying the 120 and I was not really impressed with the performance. Of coarse that was mounted on a bi-plane. High drag, etc.
Any opinions?
Jim
Any opinions?
Jim
#6094
Hi Jim,
what biplane? what prop? what fuel? have you set the rocker gap? etc. etc. etc. we need a bit more info.
Dave :^)
Dave :^)
#6095
My Feedback: (15)
LA
Hey Dave,
Your right, sorry. I run 15% coolpower and a 15x8 APC. The engine is tuned 200-300 rpm below peak. It's strong and will hover the CG ultimate. A few years ago I ran the engine in a Sportsman Aviation P-47. I thought it would be faster than it was. I tried different props on both but never saw much better performance. I also keep the tapets adjusted.
Jim
Jim
#6096
![](/forum/images/badges/premium_member.png)
ORIGINAL: rcspec
Any opinions?
Jim
Any opinions?
Jim
Looking in the Saito brochure, many of the 1.25's outer dimensions are actually SMALLER than the 1.00, such as the distance from rear of the case to the tip of the prop shaft, and from the bottom of the case to the top of the valve covers. 1.00 makes 1.8 hp, the 1.25 makes 2.2 hp.
One of the neat things about the 1.20, don't know if the others (1.25, 1.50 and up) do it, is you can exchange the intake and exhaust (put the carb on the exhaust side, run the pipe out the intake), and reverse the engine rotation. The valve timing was symmetrical, so no changes necessary to valve timing.
#6098
![](/forum/images/badges/premium_vendor.png)
My Feedback: (16)
Exchanging the position of the intake and exhaust within itself does not allow the big block engines to run backwards.
You also need a left handed cam from the 300 twin to complete the job.
http://www.horizonhobby.com/Products...odID=SAI300T34
The Saito 125 is made more like the 100 and the positions of the intake and exhaust are not interchangeable
#6099
New members:
456 mc6390
457 Hibrass
482 Robbidos
483 rtn9105
484 Biggles2
485 RockyJones
486 longflyer
487 extra-nut
488 maineflyer
Welcome.
Bill.
Moderator removed paragraph that no longer applies
456 mc6390
457 Hibrass
482 Robbidos
483 rtn9105
484 Biggles2
485 RockyJones
486 longflyer
487 extra-nut
488 maineflyer
Welcome.
Bill.
